3-цилинд. мотор BMW
Тема в разделе "Основная конференция", создана пользователем Flying Dutch, 13 сен 2012.
  1. Flying Dutch
    15 ноя 2002
    http://www.autocar.co.uk/car-news/new-cars/bmw-three-cylinder-engine-revealed
    This is the all-new, BMW 1.5-litre, three-cylinder turbocharged engine. It will find its way under the bonnet of next year’s new Mini, the new front-drive BMW family and, it’s rumoured, today’s rear-drive 1-series and 3-series models.
    Codenamed B38 (petrol) and B37 (diesel), it will come in petrol and diesel forms and is expected to be between five and 15 per cent more economical than BMW’s current N20 four-cylinder engines.
    Built on an alloy block, the engine gets Valvetronic variable valve timing, a single turbo, 11.0:1 compression ratio and a longer stroke than the N20. It has been engineered as part of BMW future modular engine strategy, which sees all engines based on the same individual 500cc cylinder.
    BMW says the petrol engine will develop between 40bhp and 66bhp per cylinder, giving the various versions power outputs of between 120bhp and 200bhp. The torque outputs are expected to be between 44lbft and 66lb ft giving a range of 132lb ft and 198lb ft.
    The B37 diesel engine shares up to 60 per cent of its architecture with the petrol engine and can be made on the same production line. The diesel engine output will range between 100bhp and 181bhp and 166lb ft and 221lb ft of torque.
    The engine is likely to first appear in the rear of the BMW i8 hybrid supercar, where it will be equipped with a generator to help recharge the battery pack. BMW's Hams Hall plant is expected to produce the new engine.
    Greg Kable/Hilton Holloway
  2. bobbeybob
    bobbeybob Завсегдатай
    6 янв 2010
  3. dephuse
    dephuse Banned
    3 ноя 2009
    1) И инженеры БМВ конструируют такие двигатели не от желания делать овощные машины, а от жёсткости законов.
    В этом мире нужно как-то выживать, т.к. существует "средняя по компании норма выброса СО".
    И чтобы существовали мощные БМВ нужно создавать и продавать овощные БМВ.
    2) Трёхциллиндровый ЭкоБуст от Форда - "Мотор года" в категории своих сообъёмников :)
  4. DNG
    DNG Абориген
    11 мар 2008
    Звук улет, аля запорожец....
  5. DNG
    DNG Абориген
    11 мар 2008
    Полностью в базе, управляемость видно нереальная..., вопрос накуя машине передок, если теперь двигло можно под торпеду запихать)))
  6. bac
    bac Новичок
    12 сен 2006
    на 1ГТ грозятся поставить 1,5л 3 горшка 190лс
  7. autofahrer
    autofahrer Старожил
    23 апр 2010
    Все и бэмэве докаталась до одноразовой китайчатины.:mad: Никогда трех цилиндровый движок не будет так мягко и эластично работать как рядная шестерка, да и звучок выхлопа не облагородит ни одна, даже самая навороченная выхлопная система. Правильно написали запорожец:facepalm:
  8. Пингвин)))
    Пингвин))) Старожил
    11 мар 2009
    Псковская обл.
    Интересно, если у 2,5 ресурс 160000км, то какой у этого будет тыщ 30000?
  9. autofahrer
    autofahrer Старожил
    23 апр 2010
    БМВ позиционирует себя как производитель элитных автомобилей, а настоящие производители элитных машин не размениваются на выпуск ширпотреба, а зарабатывают на сервисе и поддержании ранее выпущенных
  10. dephuse
    dephuse Banned
    3 ноя 2009
    Про элитные никто и никогда не гововрил.
    Если слово "ширпотреб" в вашем понимании это "товар широкого потребления", то как можно назвать а/м продающиеся милионными тиражами (вся линейка БМВ в год) :hi: ?
    upd. ощущение "элитности" могло ложно сформироваться у обывателя в СССР, т.к. по сравнению с ценой на ВАЗ цена первых привезённых сюда немецких БМВ была заоблочной.
    сейчас по вашему элита на 116LE :D ?
  11. Pessimist
    Pessimist Пессимист
    25 мар 2001
    Я думаю, что 10000.:facepalm:
  12. Pessimist
    Pessimist Пессимист
    25 мар 2001
    БМВ - элитная? Не смешно. Это не Бентли. Уж извиняйте за сравнение, но VOLVO выпускает по 250 тыс. машин в год.
  13. DNG
    DNG Абориген
    11 мар 2008
    Из оф. пресс-релиза с гугл переводом:
    Двигатель внутреннего сгорания новой концепции BMW Active Tourer является новым передовым 1,5-литровый двигатель с технологией BMW TwinPower Turbo. Производные от нескольких наград 6-цилиндровым двигателем с технологией BMW TwinPower Turbo, он сочетает в себе последнее поколение высокоточного впрыска с полностью переменная клапан системы VALVETRONIC и ультра-современные турбонаддувом. BMW TwinPower Turbo технологии будут использоваться во всех энергоблоков Эффективная семья BMW Group движок динамики в будущем - не в последнюю очередь потому, что она не зависит от общей мощности или числа цилиндров.Новый 3-цилиндровый двигатель в концепции BMW Active Tourer является одним из первых представителей нового поколения двигателей. Компактный рядный двигатель представляет собой образцовое сочетание динамических характеристик и эффективности.
    Новый BMW TwinPower Turbo 3-цилиндровый предлагает характера конкретных преимуществ: плавность хода, обороты власти, спонтанное реагирование и динамичный, спортивный звук. Так как нет первого и второго порядка, силы инерции, он предлагает особенно высокий уровень комфорта в условиях шума и вибрации. Уровень рулон крутящий момент меньше, чем у 4-цилиндрового и компенсируется за счет одного вала противовеса. Среди прочего, это помогает держать двигатель очень отлаженная в низком диапазоне оборотов двигателя, тоже
  14. dephuse
    dephuse Banned
    3 ноя 2009
    "Производные от нескольких наград 6-цилиндровым двигателем с технологией BMW TwinPower Turbo" = отпилили половину циллиндров от N55?
    "спонтанное реагирование" :shock: ВНЕЗАПНО!
    "спортивный звук" :thumbup:
  15. autofahrer
    autofahrer Старожил
    23 апр 2010
    Вот вот:D, а позиция всего форума именно такова, упаси боже задать вопрос о возможности замены неоригинальной деталью или сознаться что прикрутил гайку от таза, в раз запишут в колхозники и следовательно в нищеброды:D:D:D
  16. DNG
    DNG Абориген
    11 мар 2008
    Все верно, это половинка N55, об этом было в свое время видео, где типа отпиливают лазером половинку и вкрячивают в переднеприводную платформу и в одном интерью один из инжинеров говорил , что идут к унификации движков с литрожом 0.5 литра на горшок.
    Ждем движок 1 литр с 2мя горшками, будет бомба....
  17. xenn
    xenn Старожил
    13 фев 2008
    Мда ... под бустом и трехцилендровый двс будет эластичным. Новая реальность.
  18. xenn
    xenn Старожил
    13 фев 2008
    Это будет замена N20 ? У N20 какие перспективы ? Моща будет подниматься ?
  19. DNG
    DNG Абориген
    11 мар 2008
    Нет, конечно не будет, это будет замена 1.6 турбо и старому N46, который идет сейчас на копейках и то со временем.
  20. Coloss
    Coloss Завсегдатай
    19 сен 2011
    а что тогда с дизельным Н47? :shock:
  21. DNG
    DNG Абориген
    11 мар 2008
    тоже будет 3х цилиндровый турбодизель 1.5 литра для базовых версий
  22. Xblack
    Xblack Завсегдатай
    28 мар 2008
    Это же здорово! Какой простор для зароботка на ТО и поддержке.:)
    Так дело дойдёт что вместо замены масла на очередном ТО будут менять двигатель вместе с маслом, как оборотный.
    В своё время инженеры ВАЗа смотрели в будущее с Окой то?
  23. Всевидящий
    13 авг 2008
    Не надо ляля... количество цилиндоров уже давно не показатель плавности хода. Гидро муфта, вариаторы и прочее приспосоюление уже давно исправили ситуацию. Иначе бы все 7-ки и S классы до сих пор бы делали исключительно V12.
  24. boomkin
    boomkin Абориген
    20 янв 2012
    вы это Aston Martin рассказывать будете
  25. stonebridge
    stonebridge Старожил
    13 июл 2005
    А разве плохо, что управляемость будет вышак морда легкая, расход литров 5 похоже , да и судя по видео едет , для еденички просто оптимал, за пару лет и мерс подхватит, как и айдрайв подхватили все, а вначале -то как хаяли ...
  26. autofahrer
    autofahrer Старожил
    23 апр 2010
    И эти туда же :D:D:D
  27. autofahrer
    autofahrer Старожил
    23 апр 2010
    Все правильно! Выделенные приспособы гасят вибрации двигателя но не устраняют вибрацию собсно мотора при работе, отсюда никогда машинка с трехцилиндровым движком не даст столько комфорта, как с шестеркой. Да и почему производители грузовиков не перешли на трехцилиндровые моторы если они такие экологичные? С них-то спрос по экологии особый. Вывод напрашивается один: БМВ как и большинство остальных автопроизводителей (и не только) переходят на выпуск машин имеющих недолговечные потребительские свойства, сокращая производственные затраты с целью получения максимальной прибыли. Сугубо имхо.:hi:
  28. Pessimist
    Pessimist Пессимист
    25 мар 2001
    Плюсанусь. Практически всё в мире делается ради денег. БМВ померла в тот момент, когда кроме 3 5 7 8 серии стала выпускать ширпотреб. Кто бы и что бы не говорил. И даже несмотря на отличные двигатели.
  29. autofahrer
    autofahrer Старожил
    23 апр 2010
    Тока этих "отличных" двигателей хватает максимум на 150 ткм.:D
  30. Scofield
    Scofield Живу я здесь
    26 сен 2006
    И тут кто-то еще со своими высерами на киа лез :mad:
Поделиться этой страницей
appstore appstore
google play google play
